Fusion Manufacture
TRACE TOOLPATH
28 REPLIES 28
Message 1 of 29
neemplastmould2026
913 Views, 28 Replies
TRACE TOOLPATH
CAN YOU ADD MULTIPLE FINISHING PASSES IN TRACE PLEASE
Labels (1)
28 REPLIES 28
Message 21 of 29
ok then i will do it again
Message 22 of 29
Why not use 2D contour with compensation set to off?
Please click "Accept Solution" if what I wrote solved your issue!
Message 23 of 29
That shouldn't be needed, I don't think. Are you logged in with the same credentials as what you applied with? Our records show that you actually applied for Insider exactly one month ago and was approved.
What do you see when you go tor your Preferences?
Seth Madore
Message 24 of 29
it will create 3d geometry into 2d geometry not worth it
Message 25 of 29
i tried again but still its not working out
Message 26 of 29
You need to show me what you are seeing when you go to Preferences. While I have a decent imagination, it only extends so far when faced with a few lines of text.
Seth Madore
Message 27 of 29
Message 28 of 29
Ah! It only shows up when Compensation is set to Left or Right, not "Center", and this is intended behavior:
Seth Madore
Message 29 of 29
THANK YOU VERY MUCH
