TRACE TOOLPATH
neemplastmould2026
TRACE TOOLPATH
neemplastmould2026
CAN YOU ADD MULTIPLE FINISHING PASSES IN TRACE PLEASE
Replies (28)
neemplastmould2026
ok then i will do it again
programming2C78B
Why not use 2D contour with compensation set to off?
Please click "Accept Solution" if what I wrote solved your issue!
seth.madore
That shouldn't be needed, I don't think. Are you logged in with the same credentials as what you applied with? Our records show that you actually applied for Insider exactly one month ago and was approved.
What do you see when you go tor your Preferences?
Seth Madore
neemplastmould2026
it will create 3d geometry into 2d geometry not worth it
neemplastmould2026
i tried again but still its not working out
seth.madore
You need to show me what you are seeing when you go to Preferences. While I have a decent imagination, it only extends so far when faced with a few lines of text.
Seth Madore
neemplastmould2026
seth.madore
Ah! It only shows up when Compensation is set to Left or Right, not "Center", and this is intended behavior:
Seth Madore
neemplastmould2026
THANK YOU VERY MUCH
