TRACE TOOLPATH
TRACE TOOLPATH
neemplastmould2026
Message 1 of 29
TRACE TOOLPATH
neemplastmould2026
CAN YOU ADD MULTIPLE FINISHING PASSES IN TRACE PLEASE
Replies (28)
Message 2 of 29
Andrew_Todd
Hi Thanks for the feedback. Do you mean similar to some of our other finish tool paths? I think maybe this feature is already there?
Andrew Todd
Software QA Engineer
Message 3 of 29
weber_dominic
Yes you can check the Multiple Passes box.
Message 4 of 29
Andrew_Todd
We are still testing 'multiple passes' in Trace on an 'Insider' Feature Flag. Hopefully this will be ready for full release at some stage soon.
Andrew Todd
Message 5 of 29
TimMartin.
Right click on toolpath, click duplicate. You can add as many passes as you want this way. Use stock to leave if you want to change stepover amount. Your sideways compensation has to be set to left or right in the passes tab.
Message 6 of 29
neemplastmould2026
WELL ITS VERY COMMON FEATURE IN OTHER SOFTWARE AND AUTODESK FUSION IS STILL WORKING ON IT
I AM CREATING THIS TOOLPATH IN MASTERCAM X5 2010 SOFTWARE
PLEASE UPDATE THIS FEATURE IT WILL HELP ME ALOT
Message 7 of 29
neemplastmould2026
THEN I HAVE TO CREATE 40-50 PROGRAMME
Message 8 of 29
neemplastmould2026
NOT SHOWING IN MY FUSION 360 HOW ?
Message 9 of 29
neemplastmould2026
TELL ME WHERE ?
Message 10 of 29
Andrew_Todd
Hi. Are you signed up to the insider program?  If no then this feature will not be available to you at this time. I have inquired with the development guys and this feature will be available in a future update . Thanks.
Andrew Todd
Message 11 of 29
seth.madore
@neemplastmould2026 wrote:
TELL ME WHERE ?
You need to be a member of the Insider Program to access that feature. Membership is free, but it does involve an application process. You can apply here: https://feedback.autodesk.com/key/Fusion360Insider
Seth Madore
Message 12 of 29
neemplastmould2026
can i add multiple body stocks in manufacture ?
Message 13 of 29
seth.madore
It would be helpful to know what your goal and expectation is?
Seth Madore
Message 14 of 29
neemplastmould2026
I AM A PLASTIC INJECTION MOLD MAKER SO THERE ARE MULTICAVITES AND PUNCHES TO MACHINE
Message 15 of 29
neemplastmould2026
AMD YEAH I INSTALL FUSION INSIDER STILL ITS NOT SHOWING
Message 16 of 29
seth.madore
This is a separate question from the Trace issue you raised at the beginning of this thread
I recommend taking this new question into a new thread.
It is a Preference:
Seth Madore
Message 17 of 29
neemplastmould2026
well it still not showing
Message 18 of 29
seth.madore
Did you apply for the Insider just this morning or have you been a member for a while?
Seth Madore
Message 19 of 29
neemplastmould2026
i just deed an hour ago
Message 20 of 29
seth.madore
It's likely that you actually don't have access yet. The application and approval is entirely manual (there's a human being that reads and approves/denies the application)
Seth Madore
