Why not use 2D contour with compensation set to off?
@neemplastmould2026 wrote:
ok then i will do it again
That shouldn't be needed, I don't think. Are you logged in with the same credentials as what you applied with? Our records show that you actually applied for Insider exactly one month ago and was approved.
What do you see when you go tor your Preferences?
You need to show me what you are seeing when you go to Preferences. While I have a decent imagination, it only extends so far when faced with a few lines of text.
Ah! It only shows up when Compensation is set to Left or Right, not "Center", and this is intended behavior:
