Hi @lihongchi22
I have that option in my list, not sure why it is not showing up in yours.
You can try:
5. Click on Create copy
6. Click ok
If it still isn't there, I can export the default and you can import it.
First of all, thank you for your help. I have followed your instruction. However, that option did not show up.
Could you please export the default setting. Your effort will be sincerely appreciated.
Hi @lihongchi22
I've attached them. You will need to manually rename the extension to .printsetting
Hi @lihongchi22
I cannot attach the file for some reason.
Go to this link to download them.
