Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
There is no PLA 1.75mm option in printing setting library
4 REPLIES 4
lihongchi22
428 Views, 4 Replies
Has anyone encountered the same issue for 3d printing setup?
4 REPLIES 4
Hi @lihongchi22
I have that option in my list, not sure why it is not showing up in yours.
You can try:
  1. Click on Local
  2. Click on "Create a new print setting"
  3.  Once dialog appears, click back on Fusion 360 Library.  This should populate all print templates.
  4. Look in the list for
2020-09-10_09-27-24.png     5. Click on Create copy
     6. Click ok
If it still isn't there, I can export the default and you can import it.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
First of all, thank you for your help. I have followed your instruction. However, that option did not show up.
Could you please export the default setting. Your effort will be sincerely appreciated.
Hi @lihongchi22
I've attached them.  You will need to manually rename the extension to .printsetting
Christopher Marion
SolidCAD - Canada
Hi @lihongchi22
I cannot attach the file for some reason.
Go to this link to download them.
Christopher Marion
SolidCAD - Canada
