There is no PLA 1.75mm option in printing setting library
lihongchi22
lihongchi22
Has anyone encountered the same issue for 3d printing setup?
ChristopherMarion
Hi @lihongchi22
I have that option in my list, not sure why it is not showing up in yours.
You can try:
  1. Click on Local
  2. Click on "Create a new print setting"
  3.  Once dialog appears, click back on Fusion 360 Library.  This should populate all print templates.
  4. Look in the list for
2020-09-10_09-27-24.png     5. Click on Create copy
     6. Click ok
If it still isn't there, I can export the default and you can import it.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
lihongchi22
First of all, thank you for your help. I have followed your instruction. However, that option did not show up.
Could you please export the default setting. Your effort will be sincerely appreciated.
ChristopherMarion
Hi @lihongchi22
I've attached them.  You will need to manually rename the extension to .printsetting
Christopher Marion
SolidCAD - Canada
ChristopherMarion
Hi @lihongchi22
I cannot attach the file for some reason.
Go to this link to download them.
Christopher Marion
SolidCAD - Canada
