Fusion Manufacture
Split Face question
3 REPLIES 3
478 Views, 3 Replies
Split Face question
Hello, how come I cant select several shapes from my sketch to be part of the "Splitting Tool" in "Split Face" dialogue ? I can select other things like parts of the body but not more shapes from the sketch. Am I doing this wrong or is it just a limitation ?
3 REPLIES 3
balsmen
Hi magnusPGNJ5,
While this is a good question, you will likely have better luck if you ask in the Design/Modeling forum for Fusion - http://forums.autodesk.com/t5/design-validate-document/bd-p/124
This forum is all about CAM and has a smaller subset of people who are able to answer modeling questions.
Hope they can help!
Best Regards,
Noah
Noah Balsmeyer
Fusion Mfg Software Engineer
in reply to: balsmen
Thank you Balsmen, beeing new to this I was a bit unsure where to post this, thank you for letting me know, I will take your advice 🙂
George-Roberts
I believe the split command only allows you to select a single 'splitting tool' whether it be a sketch, surface etc.
I believe this is done on purpose. I can see how it would be beneficial in your case, but when using surfaces to split I believe it could be quite unstable using more than one at a time
