Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Fusion Manufacture
CAM HELP !!!!!!!
2 REPLIES 2
226 Views, 2 Replies
CAM HELP !!!!!!!
My name is Sergio Di Vntura and I am trying to create a tool path that cuts the edge bevel on a knife projct im working on.
I have tried using the parallel strategy and its not working, can anyone help.
2 REPLIES 2
LibertyMachine
Would you be able to share your project? Or at the very least, could you provide a screenshot showing the relevant data? Perhaps if we can see what you are trying to do we might be better able to provide some advice.
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
LibertyMachine
If you want to see an example of what you might want to try, perhaps read this discussion that I went through not too long ago:
http://forums.autodesk.com/t5/computer-aided-machining-cam/stuck-on-a-3d-pass/td-p/6233299
Seth Madore
