Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Split Face question
3 REPLIES 3
472 Views, 3 Replies
Split Face question
Hello, how come I cant select several shapes from my sketch to be part of the "Splitting Tool" in "Split Face" dialogue ? I can select other things like parts of the body but not more shapes from the sketch. Am I doing this wrong or is it just a limitation ?
3 REPLIES 3
balsmen
Hi magnusPGNJ5,
While this is a good question, you will likely have better luck if you ask in the Design/Modeling forum for Fusion - http://forums.autodesk.com/t5/design-validate-document/bd-p/124
This forum is all about CAM and has a smaller subset of people who are able to answer modeling questions.
Hope they can help!
Best Regards,
Noah
Noah Balsmeyer
Fusion Mfg Software Engineer
in reply to: balsmen
Thank you Balsmen, beeing new to this I was a bit unsure where to post this, thank you for letting me know, I will take your advice 🙂
George-Roberts
I believe the split command only allows you to select a single 'splitting tool' whether it be a sketch, surface etc.
I believe this is done on purpose. I can see how it would be beneficial in your case, but when using surfaces to split I believe it could be quite unstable using more than one at a time
