Where can I find the file MSR_MASK.a for my heidenhain 530 and 640, I need it for the new inspection cycle.
//Fredrik S
Solved by chris.steadman. Go to Solution.
Have you downloaded the latest Heidenhein Inspection Post?
yes, but thats only the post. no additional files.
Hi and thank you for using the Inspect Surface functionality in Fusion 360
The file is simple to create.
In Programming and Editing mode please create a file with the name MSR_MASK.a in the ADSK_MASK folder on the TNC. If the folder does not exist, please create it first.
Insert the following text exactly as shown including the quotes and the semi-colon at the end of the line to the first line of the file, then save the file and exit: -
"%s",QS1;
Your program should now run. I recommend you disable Commissioning mode in the post properties once you have successfully measured a part.
Please accept this as a solution if it solves your problem.
Chris
I just followed your steps and the machine still resulting in an error.
Once still not running, I’ve created a folder with the name “Fusion” in TNC:\
But still giving the error on the attached image.
If anyone has any idea, I will be very grateful.
hi,
looks like im having simmilar issues as you guys
did you found a problem?
