Fusion Manufacture
Toolpaths dont show when doing a pattern. Annoying
2 REPLIES 2
salih.akalan
176 Views, 2 Replies
What i have noticed recently is that when i make some toolpaths on an solid and want to copy them in an pattern.
It does only show the bore operations and not the rest.
This is really annoying. Check the picture below and you will se what im talking about.
2 REPLIES 2
seth.madore
in reply to: salih.akalan
Yep, known issue. However, Simulation and the posted NC code is correct. We have a ticket open to fix this, which I think is being worked on currently. I'll add this thread to the ticket!  (CAM-52423)
Seth Madore
salih.akalan
yes you are correct. i need to simulate to se that the toolpaths dont cross.
And posted code is correct. But still annoying issue that is disturbing my workflow.
Glad to hear that you have recognised and are working on a solution!
Technology Administrators
