Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Inspection missing MSR_MASK.a
6 REPLIES 6
Mikromekanik
758 Views, 6 Replies
Where can I find the file MSR_MASK.a for my heidenhain 530 and 640, I need it for the new inspection cycle.
//Fredrik S
User of Hermle and Heidenhain
6 REPLIES 6
seth.madore
in reply to: Mikromekanik
Have you downloaded the latest Heidenhein Inspection Post?
Seth Madore
Mikromekanik
in reply to: seth.madore
yes, but thats only the post. no additional files.
Hi and thank you for using the Inspect Surface functionality in Fusion 360
The file is simple to create.
In Programming and Editing mode please create a file with the name MSR_MASK.a in the ADSK_MASK folder on the TNC. If the folder does not exist, please create it first.
Insert the following text exactly as shown including the quotes and the semi-colon at the end of the line to the first line of the file, then save the file and exit: -
"%s",QS1;
Your program should now run. I recommend you disable Commissioning mode in the post properties once you have successfully measured a part.
Please accept this as a solution if it solves your problem.
Chris
Chris Steadman
Senior Manager - Machine Data and Process Insights Team
BTCouto
I just followed your steps and the machine still resulting in an error.
  1. Created the ADSK_MASK folder in TNC:\
  2. Created the MSR_MASK.a file in that folder
  3. Edited that file I’ve written "%S",QS1;
Once still not running, I’ve created a folder with the name “Fusion” in TNC:\
But still giving the error on the attached image.
If anyone has any idea, I will be very grateful.
Best regards,
Bruno Couto
Tech Support Engineer
NORCAM
silashart708
in reply to: BTCouto
if you make progress on this please reach out I have the same issues on my 530 control
hi,
looks like im having simmilar issues as you guys
did you found a problem?
