Fusion Manufacture
4th Axis cut off stock hassle
5 REPLIES 5
macmanpb
401 Views, 5 Replies
i machine a part on my 4th axis and when it's finish i want to cut off the the part from stock.
But i am found no way to do that. I tried 2d contour, flow, swarf and all im beta mode too.
The most promising operation was 2d contour with wrapping mode. But it seems it is not possible to select a circle to wrap. It is always red and dashed.
Here is an example for the cut off position.
What can i do to get this done? Have i failed to see anything?
Here is the file: https://a360.co/2AS0aoI
5 REPLIES 5
Marco.Takx
in reply to: macmanpb
Hi @macmanpb,
I did a quick look and have a maybe a solution for you.
https://a360.co/2xbcT0K
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
macmanpb
in reply to: Marco.Takx
Hi @Marco.Takx,
First, thank you for the quick reply and your work Smiley Very Happy
If i see it right, you have created a pocket and machine these. That could be a solution for now.
I am curios about to see if there other workflows out there to get this done.
Marco.Takx
Hi @macmanpb,
Couldn't let it to try more things.
I've now an open loop 2D Contour operation based on a split surface that I give some extension on the end.
https://a360.co/2QwJuXU
Marco Takx
macmanpb
You are addicted to wrap Smiley LOL
Seriously, a smart next approach, thank you for that!
macmanpb
@Marco.Takx help's me a lot to get my things done with that work arounds.
But is there no native way to do that?
