i machine a part on my 4th axis and when it's finish i want to cut off the the part from stock.
But i am found no way to do that. I tried 2d contour, flow, swarf and all im beta mode too.
The most promising operation was 2d contour with wrapping mode. But it seems it is not possible to select a circle to wrap. It is always red and dashed.
Here is an example for the cut off position.
What can i do to get this done? Have i failed to see anything?
Here is the file: https://a360.co/2AS0aoI
Solved by Marco.Takx. Go to Solution.
Hi @macmanpb,
I did a quick look and have a maybe a solution for you.
If my post answers your question Please use .Accept as Solution &
Kudos This helps everyone find answers more quickly!
Hi @Marco.Takx,
First, thank you for the quick reply and your work
If i see it right, you have created a pocket and machine these. That could be a solution for now.
I am curios about to see if there other workflows out there to get this done.
Hi @macmanpb,
Couldn't let it to try more things.
I've now an open loop 2D Contour operation based on a split surface that I give some extension on the end.
You are addicted to wrap
Seriously, a smart next approach, thank you for that!
@Marco.Takx help's me a lot to get my things done with that work arounds.
But is there no native way to do that?
