Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
4th Axis cut off stock hassle
5 REPLIES 5
macmanpb
321 Views, 5 Replies
i machine a part on my 4th axis and when it's finish i want to cut off the the part from stock.
But i am found no way to do that. I tried 2d contour, flow, swarf and all im beta mode too.
The most promising operation was 2d contour with wrapping mode. But it seems it is not possible to select a circle to wrap. It is always red and dashed.
Here is an example for the cut off position.
What can i do to get this done? Have i failed to see anything?
Here is the file: https://a360.co/2AS0aoI
5 REPLIES 5
Marco.Takx
in reply to: macmanpb
Hi @macmanpb,
I did a quick look and have a maybe a solution for you.
https://a360.co/2xbcT0K
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
macmanpb
in reply to: Marco.Takx
Hi @Marco.Takx,
First, thank you for the quick reply and your work Smiley Very Happy
If i see it right, you have created a pocket and machine these. That could be a solution for now.
I am curios about to see if there other workflows out there to get this done.
Marco.Takx
Hi @macmanpb,
Couldn't let it to try more things.
I've now an open loop 2D Contour operation based on a split surface that I give some extension on the end.
https://a360.co/2QwJuXU
Marco Takx
macmanpb
You are addicted to wrap Smiley LOL
Seriously, a smart next approach, thank you for that!
macmanpb
@Marco.Takx help's me a lot to get my things done with that work arounds.
But is there no native way to do that?
Technology Administrators
