Fusion Manufacture
3 axis swarf tool path
2 REPLIES 2
KOE_SONGSUNG
109 Views, 2 Replies
need help on 3 axis swarf tool path, unable to make it work, machine in to part. i try differnt setting none of it work. thank
2 REPLIES 2
KOE_SONGSUNG
in reply to: KOE_SONGSUNG
here a file
kellings
Did you notice that the radius of your tool is larger than your fillet radius? You can get a pretty clean toolpath using 2D trace and selecting the outer edge of the fillet, however, the side of the 1/16" tool digs into the diameter of the part since the fillet radius is slightly smaller than the radius of the 1/16" tool.
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Technology Administrators
