Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
3 axis swarf tool path
2 REPLIES 2
KOE_SONGSUNG
133 Views, 2 Replies
need help on 3 axis swarf tool path, unable to make it work, machine in to part. i try differnt setting none of it work. thank
2 REPLIES 2
KOE_SONGSUNG
in reply to: KOE_SONGSUNG
here a file
kellings
Did you notice that the radius of your tool is larger than your fillet radius? You can get a pretty clean toolpath using 2D trace and selecting the outer edge of the fillet, however, the side of the 1/16" tool digs into the diameter of the part since the fillet radius is slightly smaller than the radius of the 1/16" tool.
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
