Deleting a local tool library
tony3W49B
Message 1 of 10
tony3W49B
Fusion is not allowing me to delete a tool library that is listed under "Local".
Does anyone have any pointers of how to go about this, please?
Help is very much appreciated. I've attached a screengrab to illustrate that I'm not getting the "delete library" option when right clicking.
Thanks in advance.
Replies (9)
Message 2 of 10
jhackney1972
From your screen capture it seems you are right clicking on the wrong location.  You want to right click on a "particular" library under the Local category list and you will see the Delete command.  You will have to do delete multiple local libraries one at atime.
John Hackney, Retired
Message 3 of 10
tony3W49B
Hi @jhackney1972 ,
Thanks for your speedy response. That is actually where I am right clicking. Its probably not clear in the attachment, but I am not clicking the word 'local' I am trying to remove the libraries contained with the local library. I'm hoping i dont have to delete each tool contained within  there one by one.
Message 4 of 10
seth.madore
@tony3W49B you can't delete from the "Local" drop down, you need to select the next folder down, such as:
Seth Madore
Message 5 of 10
tony3W49B
Hi @seth.madore ,
Thanks for your response.
Please see below. Its not until I get to the individual tools, within the sub folders, that I get the option to delete.
Message 6 of 10
seth.madore
Huh. I don't think I've ever seen libraries with individual tools listed on the browser side. What happens when you revert to the old tool library in Preferences > Preview Features?
Seth Madore
Message 7 of 10
seth.madore
Where did you download that tool library from, or was it one of your own creations?
Seth Madore
Message 8 of 10
tony3W49B
@seth.madore
Its still the same, not giving me the delete option until I get to the individual tool contained within the sub folders.
Thanks for the suggestion.
Message 9 of 10
jeff.pek
What is the file structure in your tools folder? Seems like maybe the higher-level ones are actually folders?
  Jeff
Message 10 of 10
tony3W49B
@jeff.pekseems to be the case. The files were imported from a manufacturers files.
Looks like I'll have to delete the tools one by one.
Never mind, thanks all for your help.
