Advice on post-processing
Hi all,
We are starting to use Fusion 360 for Lathe CAM targeting a Mori Seiki CL253B lathe with a Mitsubishi Meldas 64 NC control and a single spindle and a rear tool turret.
I’m using the “Mitsubishi Turning” Post Processor and have noticed the ‘type’ setting that selects the active “G-code list”.
How do we tell which G-Code list is appropriate for our control, please?
By reading some of the Post Processor code I can see that the G-Code List ‘type’ values of 2 or 4 or 6 generate a Max Spindle Speed command as a G50, whereas the values of 3 or 5 or 7 generates it as a G92. Our machine needs G50 so that indicates our value should be using a ‘type’ of 2 or 4 or 6, but (without reading through all the code) how do we tell which of those it should be, please?
Also, if there is a better Post Processor that we should use with this type of control, then please shout?
Thanks.
