Cannot create any thread turning tool
slickiii
Observer Observer
Message 1 of 12
slickiii
Observer
Observer
Every time I try to create a thread turning tool, O.D. or I.D., the finished tool shows up in my library with yellow text and when I hover the mouse over the yellow text it says there is missing required data. I have changed every bit of info under every tab in the cutting tool setup page and always with the same result. I can copy the sample O.D. threading tool into another library and it will work, but if I go into the "edit tool" function, and make no changes at all, then click "accept" I end up with the same results. Also, when I go into the "cutting data" tab, I am only given the option for RPM, no SFM option.
Replies (11)
Message 2 of 12
Marco.Takx
Hi @slickiii<
I see the same behavior. But you can solve it to close the tool library and re-open it.
@jeff.pek, can you take a look at this?
Create a Threading Tool and it ends up Yellow (See below)
After close down the tool library and re-open it, the tool is Black again.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 3 of 12
ParhamsMachine
I gave it a try, but unfortunately no luck. I even tried closing fusion down and restarting, but I just cant seem to get past it.
Message 4 of 12
jeff.pek
Yes, I see the same thing. Not sure what it's complaining about. I've made sure the folks who work in this area are aware. I'd expect someone to reply with some more info soon.
Jeff
Message 5 of 12
Marco.Takx
Hi @ParhamsMachine,
Have you started the toollibrary directly, so not within a operation?
@jeff.pek, thanks for your replay. Like to hear back on when it’s been fixed.
Marco Takx
Message 6 of 12
seth.madore
Does this happen with the old Tool Library? You can turn off the new library in the Preferences > Preview Features
Seth Madore
Message 7 of 12
ParhamsMachine
Shutting off the new tool library got it to work, thanks!
Hopefully they get that fixed in the new library too
Message 8 of 12
christopher.cooperVHK2N
@slickiii Sorry to here you are having issues with the threading tools in the tool library. If you cannot clear the warning by closing and re opening the library then please turn the old library on until we can fix it.
The dev team has picked this up and we will prioritise the bug.
Chris
Christopher Cooper
Technical Consultant
Message 9 of 12
I'M HAVING THE SAME ISSUE..
Message 10 of 12
seth.madore
After closing and reopening the library, does the issue resolve itself? Does it persist through?
Seth Madore
Message 11 of 12
I CHANGE MY SETTINGS BACK TO OLD TOOL LIBRARY. WORKING OKAY WITH OLD TOOL LIBRARY.
Message 12 of 12
The team have identified the problem for the threading tool bug and are currently working on it. We will get this out to users at the earliest opportunity.
Chris
Christopher Cooper
