[BUG] Buggy, unstable and inconsistant UI and UI settings
anranlioculus
anranlioculus
1. The UI settings are not consistent for when the editor is in the main Fusion window vs. outside the main window(drag the tab into a separate window). One example is the "Hide Comments" option is missing.
The comments panel doesn't display normally when the editor is in its own window. It pops up when the file is saved for the first time during the session.
2. The collapsed UI panels automatically pop up when clicking the data panel.
WHY CAN'T WE JUST PIN THE UI IN PLACE?????????????????
anranlioculus
I feel like this is a recent BUG. Don't remember the selection filter and variant should show when editing components and footprints.
jorge_garcia
Hi @anranlioculus ,
I hope you're doing well. I'm not entirely clear on what the issue with the UI is. Depending on the size of your screen and what's open the UI may close some panels to make room for what you are now trying to open. That's by design.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
anranlioculus
Hi Jorge,
I edited the post so the screenshots are ordered accordingly. It's two issues.
I only encountered this problem after the recent update. It wasn't like this before.
This can not possibly be the intended design. See my screenshots below.
Before I opened the left side data panel, the UI panels on the right side were collapsed, which is all good.
When I opened the data panel on the left side, the available screen space became smaller. The UI panels on the right side should remain collapsed.
HOWEVER, it somehow automatically changed into tabs, which occupied more space. And it won't change back even if I close the data panel.
nnovotney
Along  this line, the document layer keeps turning on/opening, even though you keep closing it.
https://forums.autodesk.com/t5/fusion-electronics-forum/layer-keeps-turning-back-on/m-p/14189568
and it apparently was reported previously as well:
https://forums.autodesk.com/t5/fusion-electronics-forum/document-layer-keeps-turning-on/m-p/14022530
There are so many different bugs/problems/errata/workarounds in today's Fusion...where is the current bug list and recommended workarounds, or at least things to be aware of?
jorge_garcia
Hi @nnovotney ,
I hope you're well. That one has been fixed and the fix will make it into the next release of Fusion slated for October.
Best Regards,
Jorge Garcia
jorge_garcia
Hi @anranlioculus ,
Thank you for the clarification, our QA team and devs are investigating this.
Best Regards,
Jorge Garcia
