Document layer keeps turning on
tgsell
tgsell
Every time I make the slightest change in my schematic or library update, the document layer turns on in my layout.  Even when I am using my own layer set, I first need to change back to "All Layers" turn off the "document layer" and then go back to my custom layer (USER_TOP) to remove all the symbol dimensions.
jorge_garcia
Hello @tgsell ,
I'll talk to the developers about this. It seems you have components grabbed from ULtralibrarian or SnapEda, if you don't need those features on the Doc layers you can feel free to delete them.
Let me know if there's anything else I can do for you.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
tgsell
Yes, I have been using Ultralibrarian for years now.  This is new behaviour.  It used to be ok once you turned off the documentation layer every session but now it turns on with every little change...  It would be nice if I could edit the AllLayers set but at least when you are in a custom layer it should not display any layers that are not selected and definitely not turn on layers for no reason.
Closed-Loop-Bot
Thanks for bringing this to our attention. We're investigating the issue, and you can reference ticket FUS-236307 when communicating with Autodesk to find out more. Once the status of this will change, there will be a follow-up forum post made.
