I just gave the new sketch engine a test drive and the solver still kinda flips out:
pay attention to the images below: I am only moving the point with the handles visible, the other curve that is not connected gets distorded, you hardly can move the point because it swims (move problem).
I started the sketch this way I have moved the mid poitns together and later deleted the coincident constraint.
afte that moving the mid points (they are then end and start point of two splines) is going to be crazy
this is like the often reported issues where the solver gets a little crancy and your sketch gets a live on its own.
I thought with this update this was fixed. wasnt it? Maybe I misread the logs.
By the way to fix this jello like move behavior I have to deactivate the smooth and tangent handle and then I can move the end points normal again.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Claas,
As we continue to improve our sketch solver each release the focus is on issues that affect customer workflows. Can you provide a link to the logs you are referring to?
Cheers,
Mike Prom
Claas Kuhnen
Claas Kuhnen
Claas Kuhnen
