all command UI dialog are collapsed by default now!
cekuhnen
Mentor Mentor
cekuhnen
I am on win7 here.
1. every tool I start now looks like the one bellow:
as you can see everything is collapsed and for each command I use I have to expand the dialog.
Thats more than annoying.
2. How can one set this up that they will be expanded by default like this:
3. Also where can one turn off the display of the tool tip? It just wasts screen space for me?
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Hi Claas, I'm not getting that collapsed problem on Win 7, but I can get the tool tip bar to disappear by clicking the little "i" in the circle.
Jesse
cekuhnen
odd
I just restarted the PC and launched Fusion
made a sketch
solid extruded a part and the UI was expanded
called the extrude command a second time and this time the UI was all collapsed.
this is pretty annoying. it is random as it seems.
Claas Kuhnen
TimeraAutodesk
Hi Guys,
This is a known behavior right now that occurs when the new Tips and Tricks dialog is minimized (versus Hidden). If the Tips and Tricks dialog is minimized, all dialogs thereafter are minimized by default, too. To work around this, expand the Tips and Tricks dialog, "Hide" it if you don't want it open, and then proceed with your command. All new commands should be expanded now.
We're working to improve this behavior - please let us know if you run into any other issues.
Best,
Timera
cekuhnen
that work around did it! thanks!
Claas Kuhnen
