@Fueler Thanks for the feedback and sorry for the confusion, we are working hard to improve the experience. This issue here to my best estimation has something to do with data panel behavior and it would be really great to get to the bottom of it
The behavior reported in the thread is not the intended experience. I apologize for any inconveniences caused by this issue.
There are two things in the latest release that are intended to improve the data workflow experience.
- Branching and Merging has been added
- Offline Data Panel now shows project lists
If you haven't had a chance, they are discussed in further depth on the latest What's New blog post. Branching and Merging will be a very powerful way to explore and manage design variation/evolution on top of the existing version management tools provided by the loud. You'll also see we've published are next phases of improvement for the data experience on the blog post.
I note that you can always look in your locally cached files to see where the data is synced to
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
I note there are tools in place that allow you to create a local archive file in Fusion 360. You may want to check out this article on using Fusion offline.
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/simplecontent/content/working-f...
One thing that is not clear to me in this case is if Projects are missing or if Designs are missing.
You are using past tense "had" in your last comment, does that mean the issue has resolved on its own? If not could you post some screenshots of the issue and the offline issue?
The diagnostic log files (see the help menu for the command) would also be great to take a look at.
Please let me know if you have any questions. I hope this helps.
Nathan Chandler
Principal Specialist
