Unable to Edit SOME Dimensions in Sketch
perspicax
Message 1 of 25
perspicax
Fusion 2.0.20256 x86_64 [Native]
macOS 13.6.9 (22G830) on MacBookPro15,3
This keeps happening and it is HORRIBLE. I try to double-click on a sketch dimension and it will not let me edit the value. But I can click on some others and edit those. It is happening to me randomly a lot in the past week.
It keeps happening and NO, it's not the sketch being too complicated, it's BASIC sketch dimensions, I'm not doing anything crazy here. If I toggle and un-toggle Driven then sometimes I can edit it. Sometimes if I click enough other dimensions I can go back and it will let me change the value. Sometimes I have to delete the dimension and add it again, only then can I dimension it! Unpredictable! 🙂
Replies (24)
Message 2 of 25
jeff_strater
please share the design and a video (or point out an example of a dimension you cannot edit).
Possible causes:
  1. you are editing one sketch, and the dimension is in another sketch
  2. the dimension is a driven dimension, which cannot be edited
Jeff Strater
Engineering Director
Message 3 of 25
perspicax
Ok, Open this file, Open "Mounting Holes to Case" sketch, and try to edit the 2.717" dimension. Please be aware I am using MacOS Fusion!
Message 4 of 25
perspicax
Message 5 of 25
g-andresen
what I see
(view in My Videos)
günther
Message 6 of 25
perspicax
Hi Günther I have tagged this post No Gaslighting Please! So happy this works for you, but it doesn't for me; I have attached my screen record.
Message 7 of 25
jeff_strater
not quite sure why you consider @g-andresen 's post "gaslighting".  He is merely showing that he is unable to reproduce the problem.  I, also, am unable to reproduce this problem.  I am also on a Mac.  If anyone is able to reproduce this reliably, it would certainly be a high priority bug.
Jeff Strater
Message 8 of 25
perspicax
Ah yes, to clarify my comment about "No Gaslighting Please!": Often, when a user posts a real problem with Fusion on this forum, somebody (frequently a votary) will immediately respond that the user is wrong, they're using the program wrong, implying that nothing is really wrong with Fusion, and that the user's problem does not exist. Did Günther literally say that? No. Tacitly implied? Unknown, but I felt the need to remind that I have tagged this post No Gaslighting Please!
I posted a video of the problem I am experiencing, with the file, and you are telling me that the problem isn't replicable by you (or Günther)... so .... are you saying the problem doesn't exist? Do you suppose I am... not experiencing an issue? Perhaps I am not using Fusion correctly? Can you point out where in my screencast I went wrong?
Thank you for your time!
Message 9 of 25
laughingcreek
is the issue still present after closing and re-opening the model?
what about if you open the export model.  do you still have the issue?
Message 10 of 25
perspicax
Yes, any time I open the model. Yes, continues to happen with the newly imported file.
Message 11 of 25
perspicax
I want to add that it is not just this file. I have been having this issue with many files within the past week. It's only some dimensions.
Message 12 of 25
Drewpan
I would take you to task about forum members telling you they get some problem that you have to work on their
machines. This is not telling you your problem does not exist, what it is telling you is that there is something
different in what you are doing or your setup. This is a valid engineering troubleshooting method and narrows down
the issue to your system or setup. If others can reproduce the problem then it may be an actual software bug or
configuration setting.
I would also take you to task for calling one of the leading problem solvers on the forum a "votary".
a devoted follower, adherent, or advocate of someone or something.
This is fairly rude implying that those with knowledge greater than yours are somehow inferior to you.
The whole reason the forum exists is to help people learn and use fusion better and for the devs to get valid
feedback for improvement. There are those who are new and learning and do not have the skills and knowledge to
work their own problem; there are those who are experienced who offer to help; and there are those in between.
It is a work together ecosystem and the moderator stomps on anyone who becomes abusive or deliberately tries
to belittle others.
One of the three RULES pinned to the top of the forum is RULE #0. I think you need to read all of them but that one
in particular. The Gurus in this forum try to help others and you should respect they have more knowledge than you
do sometimes and if they point out certain things they are doing so to help. Sometimes you need to be humble and
accept that help even if you don't like what they say.
Cheers
Andrew
Message 13 of 25
jeff_strater
I in no way intended to say that the problem does not exist.  I am pretty sure that @g-andresen, also, did not intend to say that.  Neither of us intended to imply (and did not say) that your workflow is wrong.  Merely, that this problem is more complex than you might have realized.  While I realize that the fact that neither of us are able to reproduce the problem is not helpful to you, that information is very helpful to the Fusion team, and therefore, IMO, is a valid response here.
I am not sure how to proceed.  Hopefully it is obvious to you that the development team cannot fix a problem that they are unable to reproduce.  So, the question for us is:  what is different between your system or installation or preferences, or cache, etc and ours?  There must be some difference.  If we can determine that, we can fix this, either in your system or in Fusion itself.  To the best of my knowledge, we have never seen this problem before.  So, anything you can do to help us determine what that difference is would be helpful
Jeff Strater
Message 14 of 25
perspicax
Hello Andrew,
I do not wish to task any volunteers to try to solve bugs. I'm not asking for help, I am reporting an annoying issue. I was inspired to post this bug after the Tool window sticking over other windows in MacOS was fixed in the most recent update (if they fixed that long-time issue perhaps more generous fixes are ahead? Like being able to edit a dimension in a sketch?)
Your definition of the purpose of this forum has led me to a wonderful discovery. I JUST realized that I posted to the wrong forum! I need to be using the Support forum. I've repeatedly asked where to report bugs and only now, after your definition and reference to your own post of the rules of this forum, do I realize that is not at all the purpose of this forum, lol. Thank you!
Message 15 of 25
perspicax
Okay thank you. Not sure what more I can do to help narrow down this issue.
Probably best for me personally to use a different CAD program and import
them in, lol.
Message 16 of 25
laughingcreek
I noticed something else interesting about the file you uploaded.  dimensions that have any kind of formula in them should be preceded by an "fx:" indicating such to the user (to be clear, fusion adds the fx, not the user).  for some reason fusion isn't doing this in your model-
@jeff_strater - since this is happening after being exported and opened on a machine that has everything else working, maybe the OP's model will be helpful to the developers after all?
for reference, when I put a formula in a new sketch/model on my machine, I get the fx prefix-
Message 17 of 25
jeff_strater
@laughingcreek thanks for the pointer.  However, there is one subtlety here:  Fusion distinguishes an "expression" from an "equation".  An expression is just a math phrase that can be evaluated statically.  An equation is a math phrase that includes a reference to another parameter.  The "fx:" is only shown for equations.
expression:
equation:
Jeff Strater
Message 18 of 25
perspicax
Hello, Please see attached video showing a simple sketch where the dimension can't be edited, but when I move it to a different place it can be, and when I move it back it can't. There is NOTHING special about this sketch, what you see is it.
Message 19 of 25
davebYYPCU
Not obvious until someone tells you, make the browser smaller, or move the dimension out from under the invisible browser window.
You're not the first to get caught with this.
Might help...
Message 20 of 25
TrippyLighting
Something that strikes me as odd is that the very fist sketch, which is also the very first feature in the timeline has purple geometry in it!
Purple sketch geometry is projected geometry, which is still linked to the original object (edge or other sketch geometry from another sketch) it was projected from.
However, it being the first feature in the timeline there is no 3D object or other sketch that it could have been projected from, so how did that get there?
That is before I have even edited the sketch to look at how it is constrained and dimensioned.
Edit: That same purple geometry is part of every sketch in the design, but apparently it can be deleted without causing a problem. Unfortunately we don't have "link inspector", or a tool that would allow us to see what the projection is linked to.
