Automatically generated parts list, incorrect quantities
justinking30
justinking30
Hi, I am for the most part self taught with Fusion and I am having trouble with parts lists and the quantities  being incorrect. For starters is there any way to change the quantities in that parts list? Secondly what am I doing wrong that is causing the quantities to be incorrect?
I have made each part a separate component has I will have to make flat patterns of each file for laser cutting etc.
In the screenshot below the parts should be - Base x1, Sides x2, fixing points x2, stiffeners x4.
I have attached the fusion file as well.
Appreciate any assistance.
g-andresen
You must create Components for Partslist.
(view in My Videos)
Günther
Correction
liang_chen
Hi @justinking30 ,
In your 3D design, you create multi bodies in one component, while QTY is the component number in Part list.  You can convert the body as individual/different component, and the sub component will be counted in part list as 1, showing as attached video.  If you want the QTY of one component be 2;4, you need to insert/place the same component 2;4 times. Hope it anwsers your question.
Fred Chen
SQA Engineer
Quality Assurance Team
Autodesk, Inc.
justinking30
Thank you for your help, greatly appreciated.
