Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
twist applied to a Chain
8 REPLIES 8
Message 1 of 9
jdpreynolds
362 Views, 8 Replies
Hello
Wanting to apply a 90 degree twist over a length of Register chain 916 links).  Tried doing this manually but it turned into a bit of a mess.
Had a look at "Tanner Reids" method of creating chain behavior on the forums (2016) but couldn't get this method to work with the Register chain (imported from Mc Master Carr) I am using.
anyone got a better way of doing this?
Julian
8 REPLIES 8
Message 2 of 9
Warmingup1953
in reply to: jdpreynolds
Message 3 of 9
jdpreynolds
Thanks for your reply thats exactly what I'm trying to achieve.  How did you do that
Message 4 of 9
Warmingup1953
Labouriously I'm afraid! I created a sketch to get an axis for movement and rotation then copy move move rotate and repeated that 10 times I think. There was a false start as well
Message 5 of 9
jdpreynolds
in reply to: Warmingup1953
Yes I tried something similar but didn’t get the results you did. Will have another try using your sketch method
Thanks again
Julian
Message 6 of 9
MichaelT_123
Hi Mr Warmingup1953, Mr JDPreynolds
Is it a chain ???, ... a gold chain ???  No, it is the decorated steel bar !!!
Here is a chain, and a gold one !!!
... the whole 5.516259 ounces
... the price (without taxes and handling and insurance costs11,614 USD + 81 c
Regards
MichaelT
MichaelT
Tags (2)
Message 7 of 9
Warmingup1953
Many thanks! Edit: Sorry meant to thank MichaelT
Message 8 of 9
Many thanks! I'll dig in and investigate your approach.
Message 9 of 9
Hi Mr Warmigup1953,
Redo the shape, one sketch only and a sweep, put on X-axis anchor points and joint origins, one with a parametric off-center, add/select joints&type&motion links ... and voilà.
Regards
MichaelT
MichaelT
Technology Administrators
