Hello
Wanting to apply a 90 degree twist over a length of Register chain 916 links). Tried doing this manually but it turned into a bit of a mess.
Had a look at "Tanner Reids" method of creating chain behavior on the forums (2016) but couldn't get this method to work with the Register chain (imported from Mc Master Carr) I am using.
anyone got a better way of doing this?
Julian
Solved by Warmingup1953. Go to Solution.
Thanks for your reply thats exactly what I'm trying to achieve. How did you do that
Labouriously I'm afraid! I created a sketch to get an axis for movement and rotation then copy move move rotate and repeated that 10 times I think. There was a false start as well
Hi Mr Warmingup1953, Mr JDPreynolds
Is it a chain ???, ... a gold chain ??? No, it is the decorated steel bar !!!
Here is a chain, and a gold one !!!
... the whole 5.516259 ounces
... the price (without taxes and handling and insurance costs) 11,614 USD + 81 c
Regards
MichaelT
Hi Mr Warmigup1953,
Redo the shape, one sketch only and a sweep, put on X-axis anchor points and joint origins, one with a parametric off-center, add/select joints&type&motion links ... and voilà.
Regards
MichaelT
