Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Unable to extrude sketch
1 REPLY 1
aaronfinger
128 Views, 1 Reply
Hello everyone, I've got a sketch that I've made that I can't extrude. Inside of the sketch cant be selected, nor can the lines.
1 REPLY 1
jhackney1972
in reply to: aaronfinger
Edit your sketch, select the entire sketch, right click and select Move to Sketch Plane from the context menu. You will get a profile after this.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Technology Administrators
