Hello everyone, I've got a sketch that I've made that I can't extrude. Inside of the sketch cant be selected, nor can the lines.
Solved by jhackney1972. Go to Solution.
Edit your sketch, select the entire sketch, right click and select Move to Sketch Plane from the context menu. You will get a profile after this.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
