There are a number of constraints that I can see that fusion has automagically created. The little ruler icon and the
little triangle are equal and midpoint constraints. I can also see that some of the lines are black and some are blue.
The black lines will be constrained in some way and the blue ones are unconstrained.
Don't stress too much about being new. We all started somewhere and we are all still learning, you are just less far
down the road than some others. First thing we need to do is look at your model. Pictures are good but we can see
what you have done on the model. To Export your model go here and attach the file to your forum post.
I would strongly suggest looking at RULE #0, #1 and #2 that are pinned to the top of the forum. This will start you on
your learning. The documentation has embedded tutorials and the Self Paced Learning has step by step videos to get
you started. It is worth the time and effort to go through this stuff. Sketches and constraints are fundamental to good
modelling.
Cheers
Andrew
