tie-rod turnbuckle
tie-rod turnbuckle
zenkustumz
Message 1 of 17
tie-rod turnbuckle
zenkustumz
Good afternoon Everyone:
I am trying to figure out what and how to make an assemble relationship between the 3 pieces.. left hand thread and right hand thread so that the part works correctly.. turning the center to expand or contract the distance of the tie-rod ends..
I would like maybe a set by step so that I can understand how this is done.. Id prefer that to just having someone do it for me..
thanks in advance.. by the way this is the best group of helpers out there that I have seen..
John
http://a360.co/2a7CWxk
Replies (16)
Message 2 of 17
Beyondforce
Hey John,
You achieve this by using Motion Link:  http://www.autodesk.com/products/fusion-360/blog/creating-contact-sets-and-motion-links-in-fusion-36...
I hope it helps.
Ben.
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 17
zenkustumz
not sure how to apply this. I do understand the concept but what type of joint do I apply to the tie rod and then the turnbuckle ? Revolve to turnbuckle and slider to tie-rod?
Thanks in advance for assistance
John
Message 4 of 17
zenkustumz
Message 5 of 17
zenkustumz
i'm stuck...
Message 6 of 17
Beyondforce
I hope this helps 🙂
Cheers / Ben
Ben Korez
| YouTube
Message 7 of 17
zenkustumz
getting closer.. I think hahaha http://a360.co/2a7CWxk how do I get left hand right hand rotation based on threads? in and out movement also?
Message 8 of 17
Beyondforce
You can't really do that based the threads, but you can do rotation limits. Watch this: https://www.youtube.com/watch?v=mLJBZnEZ4qg
Ben Korez
| YouTube
Message 9 of 17
zenkustumz
can you assist me in applying the correct joint.?
Message 10 of 17
zenkustumz
Message 11 of 17
Beyondforce
Send me the file and I'll take a look at it.
Ben Korez
| YouTube
Message 13 of 17
Beyondforce
Ok, What you did was good, But what you're are trying to achieve, is impossible right now in Fusion. You can make one part rotate and another slides. One thing you forgot to-do, is to Ground the middle part 😉
If you want to simulate the the effect of both sides rotating and sliding at the same time, then you should use Motion Study.
Ben.
Ben Korez
| YouTube
Message 14 of 17
zenkustumz
that's very close.. I appreciate the assistance
John
Message 15 of 17
Beyondforce
Of course, just let me know if you more help.
I'll advice you to check out Fusion 360 Youtube channel, there are a lot of great videos.
Ben.
Ben Korez
| YouTube
Message 16 of 17
zenkustumz
just curious. is there a way to make the center piece rotate and the ends move in and out same time - same distance? As the center piece rotates clockwise they move in and counter clockwise they move out?
Message 17 of 17
Beyondforce
Maybe you can, but the assembly must have one part grounded!
Ben Korez
| YouTube
