Thicken multiple sketch line with tube
ze-adel
Message 1 of 15
ze-adel
Hi, Im a beginner to fusion 360 and even with IA help I cant figure out how to thicken multiple sketch line with tube.
For example the fantastic 4 logo I cant select the 4 and the circle and apply tube to both of them (I want both tubes to merge together) and I really prefer using tube because I can make them circle or square.
I took this example but I ll do it with various geometry and every time I tried something I have errors.
I send pictures to illustrate what Im saying.
Sorry for my poor english I m not native speaker.
And also I dont know if its useful to know but Im doing this to 3d print.
Thank you in advance for your help.
Replies (14)
Message 2 of 15
davebYYPCU
Finish the 4 tube.
New one for the circle, change cutting, to Join.
Might help….
Message 3 of 15
TheCADWhisperer
@ze-adel
Message 4 of 15
ze-adel
Hi, thanks for your answer but when I do it the sketch disapear and I need it, like I said the fantastic 4 logo is an example I need to be able to do it on dozens if not more of geometry like the one in the middle of the last picture I have sent is a piece of a bigger geometry.So I need the sketch to stay I cant redo it after one geometry it ll be a nightmare but thank you for trying to help me.
Message 5 of 15
kacper.suchomski
Hi
Attach your file.
Kacper Suchomski
Message 6 of 15
TheCADWhisperer
@ze-adel
Right click on the sketch and turn the Visibility back on.
(You can also set this in your Preferences.)
Attach your file and someone will create a video using your actual geometry.
Message 7 of 15
davebYYPCU
Use Sketch Eyeball to turn sketch back on.
In Preferences you can stop turning the sketch off after 1st operation.
Might help...
Message 8 of 15
ze-adel
Yes there it is.
Message 9 of 15
ze-adel
Ok thanks I didnt know the visibility went off I did that but the edges of the 4 are going out of the circle how do I make it fit in ?
Message 10 of 15
kacper.suchomski
Look at this:
(view in My Videos)
Kacper Suchomski
Message 11 of 15
ze-adel
Yes thanks that went well.
Message 12 of 15
davebYYPCU
Adjust the four sketch to be shorter.  It is blue so click drag the corner point.
Might help...
Message 13 of 15
ze-adel
This is what I need but I want to be able to select everything at the same time if its not possible I ll need another way to do what I want and also I found this video maybe it can help me but I dont know how to achieve it : https://www.youtube.com/shorts/1kaWQJzO_Vk
Message 14 of 15
kacper.suchomski
You can select one loop or broken line at a time.
The video you showed has little to do with the topic described in this thread.
Kacper Suchomski
Message 15 of 15
ze-adel
I found another way that work I can draw my shapes then convert png to svg and import it.
Thank you for trying to help and have a good day.
