Looking for help 3d design
Troubledfusionuser
Observer Observer
Message 1 of 11
Troubledfusionuser
Observer
Observer
Hello I am very new to fusion and I am trying to design a light shroud to hold a 9005 bulb. I have two bodies I have created but now, I would like to take the smaller part and insert it into bigger body and once finished will be rotated 90 degrees to lock.
Replies (10)
Message 2 of 11
kacper.suchomski
Hi
You have Joint and Constraint tools at your disposal.
If you don't know how to use them, attach your file.
Help:
https://help.autodesk.com/view/fusion360/ENU/?guid=ASM-CONSTRAIN-COMPONENTS
https://help.autodesk.com/view/fusion360/ENU/?guid=ASM-JOINT-COMMAND
Kacper Suchomski
Message 3 of 11
Troubledfusionuser
Observer
Observer
I am reading through now. Will that allow the three small wings to cut threads into bigger body. Thank you for reply. I tried to utilize the combine tool and cut but the smaller body disappears.
Message 4 of 11
kacper.suchomski
In the Combine dialog box, select Keep Tool.
Kacper Suchomski
Message 5 of 11
Troubledfusionuser
Observer
Observer
I did that first and it disappears. I thought there was a tool on fusion say like a bolt or propeller as body and you could rotate bolt or propeller into another body and it cuts a cavity same shape and dimensions I don’t remember what is
Message 6 of 11
kacper.suchomski
You can restore visibility in the model browser (eye icon).
Kacper Suchomski
Message 7 of 11
Troubledfusionuser
Observer
Observer
Is there a way to place smaller component into hole of larger component and leave the cavity behind
Message 8 of 11
Troubledfusionuser
Observer
Observer
I guess what I’m trying to describe would be if pushed and rotated a screw into clay and then remove the screw there would be a cavity in the shape of the screw threads. That is what I am attempting to do. Again thank you for your time and responses
Message 9 of 11
kacper.suchomski
Yes
Kacper Suchomski
Message 10 of 11
Troubledfusionuser
Observer
Observer
Do you mind explaining how
Message 11 of 11
kacper.suchomski
In the first comment I mentioned to attach your file if you are having difficulty modeling.
Kacper Suchomski
