There should be an Auto 2D Drawing dimensioning function in Fusion 360.
CLmoss
Message 1 of 143
CLmoss
There should be a Auto 2D Drawing dimensioning function in Fusion 360.  I mean, if we designed it already in Fusion, then the dimensions are all there in the files, even in the STEP files.   We have to design the project twice to get a set of dimensioned Drawings. A true automated system would do this for you.
If it exists then I have not found it.  Point me to it.
Replies (142)
Message 101 of 143
daniel_lyall
No reasion it works for me anyway I do it.
Selecting the flange command first then what to flange or selecting what to flange then selecting the flange command, actually don't do it this way I just broke it
Select Flange first.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 102 of 143
CLmoss
What?
You broke it?
More words are required here.
What didn't work?  What did work?
What broke the Fusion Sheet Metal?
Maybe I broke it too, last night?
Your public wants to know...  🙂
Message 103 of 143
daniel_lyall
At the end of the vid the flange command breaks as well.
Daniel Lyall
The Big Boss
Mach3 User
Message 104 of 143
CLmoss
You broke it.  You broke Fusion 360 Sheet Metal.  That must be what happened to me last night.
Good Job!  You just found a bug in the software.
Where is @promm the project manager?  Someone better tell him about this.
He needs to fix this before he releases the full Sheet Metal on the 8th.
I just emailed him.  He needs to hear about this.
Well, he will hear about this sooner or later.  Sooner is best.
If the Flange function is buggy then what do you have?
Message 105 of 143
daniel_lyall
I have I reported it after I posted it here, the bit at the end with the non selection yer thats a bad one it's going to be hard for them to fix as I can not reproduces it I have tried but nup wont happen again.
The double flange would be useful for 3D printing not sheetmetal.
Daniel Lyall
The Big Boss
Mach3 User
Message 106 of 143
CLmoss
So imagine releasing a SHEET METAL program that has bugs in the Flange area.  Without the Flange being reliable then you have no SHEET METAL program.  Yikes!
Intermittent is difficult, but not impossible.  It could be due to clearing of memory variables or something like that.  It could be a conflict with some other settings.  It could be pointer related.  Testing is important.  That is why we are here with the Preview version.
Message 107 of 143
CLmoss
You might not be able to easily reproduce the problem, however, you captured it on video.
Message 108 of 143
daniel_lyall
Very true I am left out in the cold so I don't know if it will get looked at.
Daniel Lyall
The Big Boss
Mach3 User
Message 109 of 143
CLmoss
I know.  Maybe @promm is on vacation.  You would think he would have chimed in here.
Well, other than the intermittent Flange bug, which your video documented, the rest of the video really hits the spot.
Good work.
Message 110 of 143
CLmoss
Can you imagine if Solidworks gets wind of this?
Since we can't do anything I should tell you I got a new cat.  My Manx (in profile photo) died a few months back.  It really was tough.
However, I adopted a 4 month old Siberian female.  What a pretty kitty.  She sits in between my keyboards.  She eats like a horse, but only weighs 8.5 lbs.
Notice who's video is on the monitor.
Also, I cannot edit "In This Design" for some reason.
Here I am in Sheet Metal and just created a new component from a Offset the Push to 0.090".
I want to make sure the In This Design is Aluminum 5052 H32.
What next?  I don't think I am doing anything wrong.
Message 111 of 143
daniel_lyall
I wont to get 2 bengal cats, or a Russian blue they are quite expensive, they are good cats to have if there is a lot of dogs or cats that hang around they wont after a few days they are meant to be good with kids as well.
A lot of people don't understand why people get upset when their pets die, my last cat I had to get put down it would jump on my back when I was useing my wood lathe and attack the chips flying off it, it was funny.
promm may well be haveing a holiday, it's sort of a good time to have it with the update coming on the 8th.
Solidworks wont realy worry about it they had their chances at doing the same thing and did not take it they will be around for ever like Autodesk.
Can you post the model from your pick, reasons if I cant edit it there is something wrong in sheetmetal or your setting if I can then it's sheetmetal on your computer or in what you set for the rules. it helps for tracing down where the fault comes from, most times it's one of 4 things, your settings should come through with the model.
Daniel Lyall
The Big Boss
Mach3 User
Message 112 of 143
CLmoss
In this first video, at 2.14 you cannot remove Steel so you rename the rule.  Does that not create a problem?  If there are rules that go with that other than those in the dialog box, they won't change.  Just the name will change from Steel to Aluminum.  Do you think that might be an issue? I can't even to do that at this point.
If I have a steel part and make a surface from it, then push to 0.090" will that also be steel or will it be the default metal which is aluminum 5052-H32?
Message 113 of 143
CLmoss
Siberians are expensive too, at least in the States, but sometimes people lose their homes and have to leave the kitties behind.
You better be ready for Bengals.  They can turn on the water and open doors.
Message 114 of 143
CLmoss
Well, here in the States no sheet metal or CNC shops I talk to has even heard of Fusion 360.  They all use Solidworks.  Everything I make has to be imported into Solidworks.  I use STEP files for them.  People use Autodesk Autocad for building homes and swimming pools.
Message 115 of 143
daniel_lyall
It should come up with your model default material you set in preferences, right click at the top element in the tree and select properties it will show what it is set to, if it is wrong goto modify - physical materials and change it there.
What it shows in the Rules for the material does not come through to the drawing.
I will ask lars if he can do a vid showing how to go from nothing to finished with setting all the settings including the physical material, A lot of people will see it that way.
Daniel Lyall
The Big Boss
Mach3 User
Message 116 of 143
daniel_lyall
My parents had a half tabby half russian blue it was the most violent cat I have ever seen my boy had a punch up with it, it was funny at the time, I have cat as there are meant to be good for you if you have heart problems or are sick or are in general a grumpy person.
I have been told if you have one bengal it is pain in the arse and are worse than a tabby and are clingy as, if you have two they are meant to be realy good then.
Daniel Lyall
The Big Boss
Mach3 User
Message 117 of 143
CLmoss
Fusion Flange just started working again.
What about on your end?
Message 118 of 143
daniel_lyall
I just had to reboot my computer and it was working again, it's a crap computer I have to reboot all the time most times it's the computer that's crashed not fusion. Never buy acer computers they are a waste of money.
Daniel Lyall
The Big Boss
Mach3 User
Message 119 of 143
CLmoss
I don't think so.  I haven't rebooted my computer in a week.
Flanges just started working again.
Maybe @promm and his developers are not on vacation.
Message 120 of 143
CLmoss
Daniel,
look at this.  This is pretty clear.   This is a class on  bending math.
https://www.youtube.com/watch?v=HemwD3NpKXk
His examples...  Whooa...  look at his finger.    Yikes!
https://www.youtube.com/watch?v=vDWYzAdRjGU&feature=youtu.be
Looks like how I do things here in my shop.
https://www.youtube.com/watch?v=I8zMdb8LrPc&feature=youtu.be
This is good too.
https://www.youtube.com/watch?v=VMu7_W0QE3Y
Bend Allowance
Bend Angle
Bend Radius
Bend Over  🙂  yuk  yuk yuk...
I was reading this calculator page from a sheet metal shop.  Not sure what to think about this.
http://www.mform.com/bend-calculator/
I am using aluminum 0.90" 5250-h32
