I wont to get 2 bengal cats, or a Russian blue they are quite expensive, they are good cats to have if there is a lot of dogs or cats that hang around they wont after a few days they are meant to be good with kids as well.
A lot of people don't understand why people get upset when their pets die, my last cat I had to get put down it would jump on my back when I was useing my wood lathe and attack the chips flying off it, it was funny.
promm may well be haveing a holiday, it's sort of a good time to have it with the update coming on the 8th.
Solidworks wont realy worry about it they had their chances at doing the same thing and did not take it they will be around for ever like Autodesk.
Can you post the model from your pick, reasons if I cant edit it there is something wrong in sheetmetal or your setting if I can then it's sheetmetal on your computer or in what you set for the rules. it helps for tracing down where the fault comes from, most times it's one of 4 things, your settings should come through with the model.
