There should be an Auto 2D Drawing dimensioning function in Fusion 360.
CLmoss
Message 1 of 143
CLmoss
There should be a Auto 2D Drawing dimensioning function in Fusion 360.  I mean, if we designed it already in Fusion, then the dimensions are all there in the files, even in the STEP files.   We have to design the project twice to get a set of dimensioned Drawings. A true automated system would do this for you.
If it exists then I have not found it.  Point me to it.
Replies (142)
Message 141 of 143
daniel_lyall
No I have not had time, yes you can go back and edit that parts rules. There's a lot sheetmetal can do it does not have all the standard stuff in it yet, but there is a lot of other stuff it can do.
Product dev is hard work.
If you just try and ram something through sheet metal it may work, I found a couple of things the sheet metal can do, one I new it may of been able to do a flat pattern of something else that is not a sheet metal part at all but can be made with sheet metal,.
And making some funky shape that needed bent in a certain way but you cant be done in sheet metal yet.
Most times when I reply to you I don't know the answer, before I reply I try what you are asking about, most times it can be done.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 142 of 143
CLmoss
Well, thank you for that!
A sheet metal shop told me this.  Does this seem reasonable?
For a 1/32 bend radius (0.03125")
0.125"     k=.195
0.090"     k=.140
0.063"     k=.100
Message 143 of 143
daniel_lyall
Yep if that's what they use.
Daniel Lyall
The Big Boss
Mach3 User
