Split a 2D sketch to CNC plasma cut larger stock than my table?
5 REPLIES 5
omamed
393 Views, 5 Replies
I have a sketch that I would like to "split" or "break" into two separate sections so that I can cut the design on my CNC plasma table.  The table will handle about 24" and the design is 48".  How do I take the sketch, cut it in half and then create G-code to cut each section, by moving the stock on the table.  I know I need to do some work to make sure things line up after the move, but can't seem to get my sketch cut in half so I can "manufacture" each half as separate cuts?  Is there a tutorial I can see, or an article that I missed?  Thanks for your help.
Labels (3)
5 REPLIES 5
jeff_strater
in reply to: omamed
up front:  I am not a CAM guy, so I can only address the sketch part of this.  If you need to split a sketch into two, there are a few ways to do it.  First, there is the "Break" command in sketch - draw a line where you want the break to happen, and then, for any curves which cross that line, use this command to split them in two.  Then, you should have clean "halves" to your sketch.  Then, since you may want to keep the original all as one sketch, I would create 2 new sketches.  In each, project the curves from one half of the original sketch.  Then, turn off the visibility of the original, and use the two 'half sketches' to drive your CNC g-code.  If you want to share a sample design, I can illustrate.
Jeff Strater
Engineering Director
etfrench
in reply to: jeff_strater
Here's another method.  Note: You can also do this in the Surface workspace which may work better for a plasma cutter.
ETFrench
omamed
in reply to: omamed
Both answers helped me a great deal!  Thank you for taking the time to reply.  I think I can now proceed!
jasonzebedee
in reply to: etfrench
hey your video i didnt get any sound from, can you send it to me? it looked exactly what i needed   thanks
etfrench
in reply to: jasonzebedee
Your in luck because all of the information you need is already in the video.  The lower part of the video shows each command and which dialog is open.  Just slow the video down and pause it at each point of interest.
p.s. I don't have a copy of it and didn't record sound when it was made.
ETFrench
