- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a sketch that I would like to "split" or "break" into two separate sections so that I can cut the design on my CNC plasma table. The table will handle about 24" and the design is 48". How do I take the sketch, cut it in half and then create G-code to cut each section, by moving the stock on the table. I know I need to do some work to make sure things line up after the move, but can't seem to get my sketch cut in half so I can "manufacture" each half as separate cuts? Is there a tutorial I can see, or an article that I missed? Thanks for your help.
