Set position constraint to linked body
3 REPLIES 3
tampe125
2481 Views, 3 Replies
I'm moving the first steps with Fusion 360 so most likely I'm doing something wrong.
I created a plate and on top of this plate I'll attach some bodies (linked from other designs).
I have created constructions lines to align objects; since I'm going to experiment with different distances between the bodies, I have created a couple of User Parameters in order to create a dynamic grid.
I can link external designs just fine and I can move bodies in the correct position, however I wasn't able to create a constraint to link the body to the grid, so when I change the distance between construction lines objects will move too.
Is that possible or am I doing something wrong?
3 REPLIES 3
etfrench
in reply to: tampe125
Use joints instead of the Align tool.
ETFrench
mavigogun
Are you using joints?    First I created my grid, then Coincident Constrained Points to the grid nexus by applying the Constraint to the Point and both the lateral and longitudinal Lines.   I then placed Joint Origins at each Point.   Mindful that Joints play nice with Components, each Body I wanted to position was included in one.   Then Assemble>Joint, selecting the target Component and desired Joint Origin.   There after, moving a line moves the Component. Grid Positioning.JPG
tampe125
in reply to: mavigogun
Thank you very much, works like a charm!
