- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm moving the first steps with Fusion 360 so most likely I'm doing something wrong.
I created a plate and on top of this plate I'll attach some bodies (linked from other designs).
I have created constructions lines to align objects; since I'm going to experiment with different distances between the bodies, I have created a couple of User Parameters in order to create a dynamic grid.
I can link external designs just fine and I can move bodies in the correct position, however I wasn't able to create a constraint to link the body to the grid, so when I change the distance between construction lines objects will move too.
Is that possible or am I doing something wrong?
