Hi @scott.nortman, @jhackney1972 and @SpecialJ,
A little bit of good news, revision tables, as well as revision markers and clouds are coming. Here's a sneak peak. It's still very much in development so we don't have a release date yet, but it's scheduled for early next year.
And while I have your attention, quick question... when revising a multi-sheet drawing, are all sheets revised as a set (all sheets move from A to B to C at the same time), or is each sheet revised separately (sheet 2 moves from A to B to C, while sheet 1 remains at A)?
And regarding the roadmap, thats just our way of sharing with you all our plans for the coming months. Not every project is included, some do slip through without getting included. Revision management (tables, markers and clouds) is included and shown as in progress.
Hope this helps. Looking forward to hearing you thoughts on revising multi-sheet drawings.
Cheers, Andrew
BTW, if you take a closer look at the toolbar, you may see a few more features that are in the works
Andrew de Leon
Experience Designer - Fusion 360
MacBook Pro (16-inch, 2019), OSX 10.15.7, in Sydney, Australia
