Centerline tool issues
scott.nortman
scott.nortman
There seems to be an issue when I attempt to create a centerline on  a cross section view:
https://drive.google.com/open?id=1N9rxGDs8RvovSBPyykIrl6DI8lQufSdR
Perhaps I am not using the tool correctly?
jhackney1972
I created a Screencast showing you the Centerline tool in action on a model I think is identical to yours.  Please share your model and drawing so the Forum users can troubleshoot it for you.  In the future, you should use the Autodesk Screencast recording tool for your videos, it is free and probably was already installed with Fusion 360.  If not just search for Autodesk Screencast on the web.  Users are a little concerned using outside links.
John Hackney, Retired
jhackney1972
I forgot to mention, the feature you are trying to place the centerline in must be created from a true circle.  You did not show the source of the section so I cannot tell.
scott.nortman
Thanks for the response!
I am not able to attach the file as it is proprietary; I will review your video.
Scott
