Revision Table?
Revision Table?
scott.nortman
Message 1 of 19
Revision Table?
scott.nortman
I thought in an earlier version of Fusion there was the ability to add an empty table where I was able to manually add print revisions; however, now I am only seeing an option to add an auto-populated BOM table, even for a single part.
Is there an option to add a revision table with manual entries?
Replies (18)
Message 2 of 19
jhackney1972
You can add a empty table and fill it in manually with information of your choosing but that is it.  Revision tables may be on the drawing roadmap for development, I cannot say.
John Hackney, Retired
Message 3 of 19
scott.nortman
I had thought that an empty table was possible in a prior version of Fusion, but I can not seem to find the proper way to do this with the latest revision; when I click on the 'TABLES' table, the only option I can see is for a Bill of Material table this is auto populated and not changeable.
Message 4 of 19
jhackney1972
Message 5 of 19
SpecialJ
In all fairness, a rev table, BOM table (cutting schedule), Are standard equipment on engineering drawings. I don't think it needs to be on a roadmap to implement basic functionality.
Message 6 of 19
andrew.de.leon
Hi @scott.nortman@jhackney1972 and @SpecialJ,
A little bit of good news, revision tables, as well as revision markers and clouds are coming. Here's a sneak peak. It's still very much in development so we don't have a release date yet, but it's scheduled for early next year.
And while I have your attention, quick question... when revising a multi-sheet drawing, are all sheets revised as a set (all sheets move from A to B to C at the same time), or is each sheet revised separately (sheet 2 moves from A to B to C, while sheet 1 remains at A)?
And regarding the roadmap, thats just our way of sharing with you all our plans for the coming months. Not every project is included, some do slip through without getting included. Revision management (tables, markers and clouds) is included and shown as in progress.
Hope this helps. Looking forward to hearing you thoughts on revising multi-sheet drawings.
Cheers, Andrew
BTW, if you take a closer look at the toolbar, you may see a few more features that are in the works
Andrew de Leon
Experience Designer - Fusion 360
MacBook Pro (16-inch, 2019), OSX 10.15.7, in Sydney, Australia
Message 7 of 19
scott.nortman
For a multi sheet print, I always keep all sheets at the same revision
level.
Message 8 of 19
jhackney1972
I agree with @scott.nortman , all sheets should carry the same revision level.  The other proposed additions look great as well!
Message 9 of 19
brysonwhitedesign
Same here. Please roll all sheets at once, keeping the entire drawing at the same revision!
Message 10 of 19
brysonwhitedesign
Also, please have the revision table snap to the corner of the drawing template. Right now it appears that there in no way to snap a table to the drawing template. Or am I missing something?
Message 11 of 19
Hi Andrew,
Any news on implementation of revision tables, markers, etc.?
Br, Ask.
Message 12 of 19
tien.tnEJZWK
@andrew.de.leon Hi Andrew, we still waiting for revision tables. Could you update the status for this? Thank you.
Message 13 of 19
rohit.bapat
Hello @tien.tnEJZWK
I am Rohit Bapat, Product Owner for the team which is working on the Revision Management feature. The revision management feature is being worked upon actively and we are coming to the closure. Soon, it will come to validation phase. There are several new behaviours which will get introduced with this feature which also added some complexity under the hood. I know it's been a while since we are working on this feature. But, rest assured, we are actively working on this feature and soon it will be available for the customers.
Rohit Bapat
Product Owner
Message 14 of 19
rohit.bapat
Hello All,
I am happy to announce that the Revision Management (Revision table, Revision markers and Revision clouds) is now released in the latest update of Fusion 360 https://www.autodesk.com/products/fusion-360/blog/march-2022-product-update-whats-new/
Please feel free to use and let us know if you have any queries or concerns.
Rohit Bapat
Product Owner
Message 15 of 19
eric.meijer487FF
Is there a possibility to add the revision table to the template?
Because at this moment I have to redo every revision table Text size and which columns to show or hide for every drawing. Also is there a way that the text height in the revision table can be set to 2.5 mm standard?
Now I do it manually, but when I add a new revision it automatically changes the text height of the new revision to 3.5 mm.
Message 16 of 19
ClintBrown3D
Hi @eric.meijer487FF
We do plan to add support for Rev Tables in templates. I've added it to the Public roadmap under “Management”.
The size of the test in the revision table comes from the text height group. Tables, Dimensions, and Notes all use the medium text height group, which by default is 3.5 mm, you could change this and set all Medium text to 2.5 mm if you'd like. Here's a bit more info on text height groups.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
Message 17 of 19
jordan_williamsBT62D
Community Visitor
Community Visitor
Has any progress been made on adding revision tables to templates? Do we have a timeline for its introduction?
Message 18 of 19
ClintBrown3D
Hi @jordan_williamsBT62D
This is on our public roadmap under “Management”. You can follow our progress by following the link below in my signature (note you will need to sign up for Mural and request access).  There is also a link to my calendar to chat directly with me, on a 1:1 Zoom call, I can share a bit more about our plans and what we're looking to build over the coming months.
Clint Brown
Message 19 of 19
ClintBrown3D
Hi Everyone
Thank you for your patience, we shipped Revision Table support for drawing templates today, see the January What's new here: https://www.autodesk.com/products/fusion-360/blog/january-2025-product-update-whats-new/#drawings
Clint Brown
