Rev Version Mix Up
Rev Version Mix Up
AnthonyPlechacek
Rev Version Mix Up
AnthonyPlechacek
The Screencast below shows, that I could not create a technical drawing for the was working on, because it was showing an obsolete version of the drawing.
daniel_lyall
@AnthonyPlechacek drawings only work with components. you can convert the body to a component then it will work.
or start again using R U L E 1 save, name, start a component then make sure it's active.
if you won't to know more about rule 1 search the forum it's a hot topic or you can watch this vid at 14 mins it has about rule one https://www.youtube.com/watch?v=VbSkwvZyU_0
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
AnthonyPlechacek
@daniel_lyall While that did fix my issue, the error did not occur when I tried to roll the version back and create a drawing again. This leads me to believe that this is not the core issue, but rather something else. Also I didn't have this problem before when creating drawings from bodies.
