Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Randomise the wood texture on a wood siding
5 REPLIES 5
paysagine
291 Views, 5 Replies
When I want to apply a wood texture on lots of objects like wood siding. The same wood grain and notche are applied and repeated. I would like to know how randomise the wood texture if it's possible.
Thanks.
Alex
5 REPLIES 5
TrippyLighting
in reply to: paysagine
Manually on each face/body/component (whatever you have applied the texture to) using the texture map control.
@TrippyLighting - I had no idea this would work even for solid wood appearances, but it does.  Now, I have a LOT of work to do to update my log cabin model so that it looks better, less repetitive.  Thanks!!!  Proves that you can always learn something!
Jeff Strater
Engineering Director
paysagine
in reply to: TrippyLighting
Thanks but when you have more than 200 objects the solution take lot of
time.
For few object it's the solution
TrippyLighting
With the normal tools available through the UI, that’s what you got!
Unless you are familiar with Python and can use the Fusion 360 API. That might be the only other solution reduce the amount of work.
paysagine
Hello
I tried but with the same components, texture was not dissociate. All texture map control move in the same direction for all components. Sorry
