Project sketch, a lot of points
cristianmatabanchoy
cristianmatabanchoy
Hi!
First of all I had to create an account because with my usual account, it gets buggy when I try to enter the forums.
So, does anyone know why when I do a projection, I get so many dots? It is only in the projection, when I make the drawing as the larger circle comes out normal.
The only different thing is that I copied this file from another file, and all the faces and bodies that I try to project I get dots.
davebYYPCU
Imported geometry - there are file conversion to Fusion compatible things going on.
Not checked the file.
Might help….
jhackney1972
I have previewed all of your sketches and I do not see one containing the points you describe.  I also project the edge you circled into a new sketch and also did not see the points you describe.  Please attach your model and identify which sketch you are referring to.
John Hackney, Retired
cristianmatabanchoy
Yes sorry I uploaded the wrong file, I just uploaded it again.
cristianmatabanchoy
Hello!
So inside the Fusion360 panel I right clicked copy and in the same panel the project was copied, it was an internal copy.
HughesTooling
Because the cylinder is not concentric with the sphere the edge is not a circle when you project the edge to a sketch perpendicular to the cylinder. If you try projecting the surface then you get the 2 surface edges so again not a simple circle.
What you actually get is a spline. If you zoom in you can see the control points.
The only thing you could do is create a plane through the middle of the cylinder then use project intersect to create a circle at the intersection then project to your sketch.
See attached file.
Mark Hughes
Owner, Hughes Tooling
cristianmatabanchoy
Hi!
Yes sir that was the problem, I just projected as I was expecting.
Thank you!
