Problems installing the new update
3Dpcb
3Dpcb
Apparently I have the latest version, but with errors.
How to delete my update and install a new one or is there a different approach.
I have also attached "Fusion360DiagnosticLogs".
marshaltu
The error "Addin start failed" was because the addin you downloaded from Exchange Store didn't work in new Fusion. Please uninstall and download updated one from Exchange Store again.
Marshal
Marshal Tu
Fusion Developer
prabakarm
@3Dpcb the errors seems to be due to the exactflat app you downloaded from the exchange store needs to be updated for the June update.  Can you try unsintalling the current add-in and getting the latest from the exchange store.
https://apps.exchange.autodesk.com/FUSION/en/Detail/Index?id=appstore.exchange.autodesk.com%3aexactf...
Prabakar.
marshaltu
In case you have no idea how to "uninstall" the addin "ExactFlat Online Publisher". Please follow the steps as below:
1. Go to the folder "/Users/boldsen/Library/Containers/com.autodesk.mas.fusion360/Data/Library/Application Support/Autodesk/ApplicationPlugins" and find the file "ExactFlatOnlinePublisher.bundle" and delete it.
2. Go to the folder "/Users/boldsen/Library/Application Support/Autodesk/ApplicationPlugins" and file the link "ExactFlatOnlinePublisher.bundle" and delete it.
3. And then go to "https://apps.exchange.autodesk.com/FUSION/en/Detail/Index?id=appstore.exchange.autodesk.com:exactfla... and download the latest "ExactFlat Online Publisher" and reinstall.
Marshal
Marshal Tu
Fusion Developer
3Dpcb
Thank you for your help. Everything now works perfectly.
I just deleted ExactFlatOnline inside Fusion360 - Scripts and Add Ins.
